Written by This email address is being protected from spambots. You need JavaScript enabled to view it.
Nios® II is an softcore 32-bit processor developed by Altera to be implemented over all Altera (INTEL) FPGA and SoC families.
Some NIOS-II-e Gen2 features:
- No license required.
- Use fewer than 700 logic elements.
- 6-stage pipeline runnning up to 30 DMIPS at 175 MHz in Nios II /e "economy" processor (Dhrystones 2.1 benchmark).
- Deterministic and jitter free real-time performance.
- Vector Interrupt Controller.
- Custom instructions (ability to use FPGA hardware to accelerate a function).
- Supported by industry-leading real-time operating systems (RTOS).
- Nios II fast processor core can use a memory management unit (MMU) to run embedded Linux* operating system.
One way to optimize hardware resources use of Nios-II processor is implementing an real Time Operating System (RTOS) and NIOS-II is a excellent processor to run RTOS. Nios-II processor is supported by a lot of RTOS and one of the most popular and robust is the FreeRTOS.
Some FreeRTOS features:
- Free for use in commercial applications.
- Scalable, simple and easy to use.
- Simple - the core of the RTOS kernel is contained in only 3 .C files.
- Scheduler can be configured for both preemptive or cooperative operation
- Free tutorial books and training to educate engineers
In this article, we present all steps to implement the last FreeRTOS (v9.0) versión over the NIOS-II processor. All step presented area developed in Quartus II 17.0 version and tested in DE0-nano development board.
Create Project using "DE0 Nano System Builder"
![Create Project using "DE0 Nano System Builder"](http://imageshack.com/a/img922/2672/rlWyOw.png)
Open project using Quartus 17
From Quartus: File, Open Project..
![Open project using Quartus 17](http://imageshack.com/a/img922/1324/zpJLSi.png)
Create NIOS-II instantiation using Qsys tool
- From Quartus: Tools, Qsys..
- Save as niosII.qsys
- From IP catalog, include this components and configure.
- Interconnect all components included in project in the next way.
![NIos-II interconect](http://imageshack.com/a/img924/4682/s1Fw8b.png)
Generate HDL of NIOS-II instantiation.
- From Qsys: Generate, Generate HDL...
![](http://imageshack.com/a/img924/435/TztX4T.png)
Connect NIOS-II HDL with FPGA hardware pins.
- write follow code in Quartus project, verilog file.
niosII u0 (
.clk_clk (CLOCK_50), // clk.clk
.epcs_dclk (EPCS_DCLK), // epcs.dclk
.epcs_sce (EPCS_NCSO), // .sce
.epcs_sdo (EPCS_ASDO), // .sdo
.epcs_data0 (EPCS_DATA0), // .data0
.port_led_export (LED), // port_led.export
.port_key_export (KEY), // port_key.export
.port_sw_export (SW), // port_sw.export
.port_gpio_0_export (GPIO_0[31:0]), // port_gpio_0.export
.ram_clk_clk (DRAM_CLK), // ram_clk.clk
.reset_reset_n (1'b1), // reset.reset_n
.uart_rxd (GPIO_0[32]), // uart.rxd
.uart_txd (GPIO_0[33]), // .txd
.sdram_addr (DRAM_ADDR), // sdram.addr
.sdram_ba (DRAM_BA), // .ba
.sdram_cas_n (DRAM_CAS_N), // .cas_n
.sdram_cke (DRAM_CKE), // .cke
.sdram_cs_n (DRAM_CS_N), // .cs_n
.sdram_dq (DRAM_DQ), // .dq
.sdram_dqm (DRAM_DQM), // .dqm
.sdram_ras_n (DRAM_RAS_N), // .ras_n
.sdram_we_n (DRAM_WE_N) // .we_n
![](http://imageshack.com/a/img922/7978/GVvfvI.png)
Include NIOS-II HDL to Quartus Project
- From Quartus: Project, Add/Remove files in Project..
- Add niosII.qsys file to project.
![](http://imageshack.com/a/img922/1517/KiBVqO.png)
Compile Quartus project
- From Quartus: Processing, Start Compilation.
![](http://imageshack.com/a/img923/708/A9FyCS.png)
Programming FPGA DE0-nano.
- From Quartus: Tools, Programmer
- click over Start Button
![](http://imageshack.com/a/img923/4808/D8fVGk.png)
Create C/C++ project from Eclipse IDE
- From Quartus: Tools, Nios II Sofware Build Tool for Eclipse.
- Select a workspace
- From Eclipse: File, New, Nios II Application and BSP from Template
![](http://imageshack.com/a/img923/5543/JIz7aA.png)
- Create NIOS II application from template
- Nios II SOPC: Search for niosII. sopcinfo in to project folder
- Project Name: Whatever you want
- Project Template: Hello World
- Finish
![](http://imageshack.com/a/img923/6512/BtICg9.png)
Import FreeRTOS to Eclipse Project
![](http://imageshack.com/a/img924/5445/PR9VVv.png)
- Include FreeRTOS folders to compile path in properties of Eclipse Nios Project.
![](http://www.coffeebrain.org/wiki/images/4/43/ConfigFreeRTOS_2.png)
Edit hello_wolrd.c to create task and run FreeRTOS.
In this example, in hello_wolrd.c are created two task. This is the "hello_world.c" code. Copy and paste in your own eclipse project.
* [File Name] hello_world.c
* [Platform] DE0-nano
* [Project] NiosII & FreeRTOS
* [Version] 1.00
* [Author] ea.rincon11 - ErnestoARC
* [Date] 24/07/2017
* [Language] 'C'
* [History] 1.20 - Edited from original file included in FreeRTOS V9.0.0 Nios Example
// Standard C/C++ Includes
#include <stddef.h>
#include <string.h>
// Scheduler Includes
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "partest.h"
// Constants
/* The rate at which the Print out message controlled by the 'Task1' */
#define mainTASK1_PERIOD ( 500 )
/* The rate at which the Print out message controlled by the 'Task2' */
#define mainTASK2_PERIOD ( 1000 )
/* Priority definitions for the tasks in the demo application. */
#define mainTASK1_PRIORITY ( tskIDLE_PRIORITY + 1 )
#define mainTASK2_PRIORITY ( tskIDLE_PRIORITY + 2 )
// Function Prototypes
static void prvPrintTask1( void *pvParameters );
static void prvPrintTask2( void *pvParameters );
// Main Function
int main()
/* Configure any hardware required for this demo. */
vParTestInitialise();
printf("Hello from Nios II!\n");
/* prvPrintTask1 uses sprintf so requires more stack. */
xTaskCreate( prvPrintTask1, "Task1", configMINIMAL_STACK_SIZE, NULL, mainTASK1_PRIORITY, NULL );
/* prvPrintTask2 uses sprintf so requires more stack. */
xTaskCreate( prvPrintTask2, "Task2", configMINIMAL_STACK_SIZE, NULL, mainTASK2_PRIORITY, NULL );
/* Finally start the scheduler. */
vTaskStartScheduler();
/* Will only reach here if there is insufficient heap available to start
the scheduler. */
for( ;; );
return 0;
for( ;; )
/* Wait until it is time to run the tests again. */
vTaskDelay( mainTASK1_PERIOD / portTICK_PERIOD_MS);
/* Print out an message */
printf( "NIOS II Task1\r\n" );
/*Control LED 1 DE0-NANO*/
vParTestToggleLED(1);
for( ;; )
vTaskDelay( mainTASK2_PERIOD / portTICK_PERIOD_MS);
printf( "NIOS II Task2\r\n" );
/*Control LED 2 DE0-NANO*/
vParTestToggleLED(2);
// EOF
Compile and Program FreeRTOS Project into FPGA with NiosII
- From eclipse: Project Build All
- From eclipse: Run, Debug Configurations...
- Click DEBUG and RUN debugger
![](http://imageshack.com/a/img922/4333/XL0v8o.png)
![](http://imageshack.com/a/img924/8913/xKOgXl.png)
![](http://imageshack.com/a/img923/850/qo2mko.png)
Download complete project.
If you don´t want follow this steps, then download the Quartus, Qsys and Eclipse project.
