Hits: 41968
The PWM module varies the duration (time) of the high and low states of an output signal based on an internal count (modifiable Nbits) and a comparison (duty and period). This has various applications in the field of electronics, ranging from control to digital communications. PWM can be used to control the speed of a motor, among other applications.
Figure 1 – PWM Module.
Equations:
FRECpwm=output frequency of the module in Hz
CLKin= Input clock frequency in Hz
PERIODOpwm=Max value of the internal counter of the PWM.
Note: The maximum value of Duty[n:0] is determined by the value of the Period.
Example 1 (Modular instantiation):
If you want Frec_pwm = 20KHz and you have a period = 250, what should be the input clock frequency to the PWM module?
If we apply the formula given earlier:
Example 2:
Let's assume CLK_in = 50MHz, Nbits = 3, Period = 7, and a fixed duty = 3.
How would the output signal of the PWM module look and what is the period of the signal?
Figure 2 - Annotated simulation of the PWM module.
Figure 3 - Simulation of the PWM module
Applying the formula, it would be:
Verilog Module(PWM.v):
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:    18:31:09 06/04/2009
// Design Name:    Jose Pablo Pinilla & Holguer A Becerra
// Module Name:    PWM
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module PWM #(parameter Bits_counter = 7, Periodo=3'd7)
	 (	input  clk, output motor, input  [Bits_counter-1:0] duty_cycle);
   reg [Bits_counter-1:0] Timer1=0;
   reg PWM_OUTPUT;
	assign motor = PWM_OUTPUT;
   always @(posedge clk)
		if (Timer1 >= Periodo)
					Timer1 <= 0;
					PWM_OUTPUT<=PWM_OUTPUT;
				  Timer1 <= Timer1+1;
				  if (Timer1 >= duty_cycle)
						 PWM_OUTPUT<=1'b0;
						PWM_OUTPUT <= 1'b1;
